I’ve tried to understand an issue I sometimes have when working with cine raw from my phantom camera. I did a shot this week at 1000fps. I am compositing a time lapse background behind a stop motion of an Altra trail running shoe and then it cuts to the high speed shot which is a view from straight under the shoe showing the sole as the runner passes over camera. I often use retime curve and change the speed of the shot as I did in this case. Sometimes i get playback that is not smooth so it can be difficult to see detail clearly, like the altra logo on the sole of the shoe. I mainly stabilized the shot set to “Translation” with “camera Lock” checked and also “Zoom” checked. this seemed to help but I also played the desired part of the clip at 80% which also seemed to help but I always think it can be better.
I thought of you and thought I’d get you a shout. Maybe there are different things to try. I’d like to have different options as every case seems a bit different. I often shoot at 1000fps and sometimes up to 2000fps and OCCASIONALLY at 600-800fps.
project I am working on is 24p.
Thanks
Dennis
