DaVinci Resolve Power Windows Explained
Learn fast masking, tracking, and isolating areas to enhance your shots with precision.
I think it will be necessary to explain clip and frame options in a tracker window, because a lot of adjustments depend on whether a clip or frame button is selected.
I’m not sure what you mean here. When on clip you offset the whole clips track and when on frame you offset that frames track.
Exactly. However, this should be mentioned in the beginner’s tutorial - how each option affects tracking.
