DaVinci Resolve 20 Public Beta 4 is now out
Blackmagic Design just dropped DaVinci Resolve Studio 20 Public Beta 4, You can grab it now for free from their support site: DaVinci Resolve Latest Downloads
Here’s a breakdown of the exciting new features and bug fixes in Beta 4:
  • New flat mode for keyframes easing.
  • Option to show clip handles for curves editor.
  • Context click curve keyframes to quickly access easing options.
  • Scripting API support for media pool clip to monitor growing file.
  • AI Voice Convert is now available in the Fairlight timeline context menu.
  • DaVinci Remote Monitor app now supports Intel and AMD systems on Windows.
  • Interpolated animation support for manually created and imported subtitles.
  • DCTL encryption option for non-LUT DCTLs from LUT browser context menu.
  • Addressed subtitle animation issue when adding new words.
  • Timelines created from AI IntelliScript now use the script name.
  • Addressed an issue with Multicam SmartSwitch and some Nvidia graphics cards.
  • Addressed issue with MultiText layer naming when deleting text layer.
  • Addressed incorrect countdown pause for the first voiceover in a session.
  • Addressed cut page UI issues switching between portrait and landscape layouts.
  • Addressed keyframe reset not affecting keyframes in clip handles.
  • Addressed an issue changing source clip color from source timeline.
  • Addressed issue with arrow key navigation in media pool with custom sort.
  • Addressed issues with find in media pool when viewing source tape in the edit page.
  • Addressed issue with enabling AI Super Scale from the inspector.
  • Addressed issues with AI Super Scale and Video HDR on Nvidia RTX graphics cards.
  • Addressed a crash with AI Voice Convert on Nvidia RTX graphics cards.
  • Addressed incorrect Remove Silence behavior for clips with audio channels set to none.
  • New Swizzler tool to rearrange layers in multi layer workflows.
  • Addressed issue with previewing mismatched pixel aspect ratio media in Fusion.
  • Addressed issue with 24 hour timecode display preference in some timecode displays.
  • Addressed Magic Mask cache reset when toggling a post clip group node.
  • Automatically resync media files should only work on bins with same names as folder.
  • Addressed quick exports ignoring timeline render resolution setting.
  • Addressed macOS preferences menu issue when interface language was set to French.
