DaVinci Resolve 20 Public Beta 3 is now out
Blackmagic Design just dropped DaVinci Resolve Studio 20 Public Beta 3, and it’s packed with updates! You can grab it now for free from their support site: DaVinci Resolve Latest Downloads
Important Note on Compatibility: While they’ve worked hard to maintain project library compatibility with DaVinci Resolve 19.1.3, projects created or opened in Resolve 20 will NOT be accessible in 19.1.3. Back up your project libraries AND individual projects before diving in!
Here’s a breakdown of the exciting new features and bug fixes in Beta 3:
New Features:
  • Chroma Warp Support in Advanced Panel: The DaVinci Resolve Advanced Panel’s tools menu now supports Chroma Warp.
  • Editable MultiText Layer Names: Now you can edit MultiText layer names directly in the inspector.
  • Source Tape Visibility: The edit page source timeline view now shows the source tape.
  • Improved Source Key Functionality: The Edit keyboard Source key now recalls the last edit page source viewer mode.
  • HDR Report Enhancement: The HDR report now includes a MaxCLL MaxFALL graph.
  • GPU Accelerated Encoding: GPU-accelerated interlaced H.264 encodes are now available on Nvidia Blackwell GPUs.
  • Scripting API Enhancements: New scripting API support for linking full-resolution media and replacing media pool clips while preserving sub-clip extents.
Bug Fixes:
This beta release addresses a significant number of bugs across various aspects of the software. Here are some key fixes:
  • Addressed issue with character level styling on selected MultiText layers.
  • Addressed issue with modifiers on duplicated MultiText layers.
  • Addressed issue animating subtitles for some languages.
  • Addressed issue highlighting initial word in some animated subtitles.
  • Addressed multiple issues with the keyframe and curves editors.
  • Addressed issue with proxy and audio sync for media pool subclips.
  • Addressed incorrect default location for render in place.
  • Addressed cache refresh issue when editing text titles.
  • Addressed AI music editor inspector controls sometimes not shown after unlinking audio clip.
  • Addressed media management trim issue with multi-mono wav audio.
  • Addressed sensitivity issue with HDR global track ball in the advanced panel.
  • Addressed potential Magic Mask cache invalidation on project load.
  • Addressed switch clip with same node behavior in multi-user projects.
  • Transform direction control is now in Fusion OCIO Display tool and view LUT.
  • Addressed color preview in Fusion Media Out invalidating Magic Mask color cache.
  • Addressed Fusion aux channels showing as black in color managed projects.
  • Addressed playback and render performance for Fusion nodes with disk caches.
  • Addressed issue with Cryptomatte tools in color managed projects.
  • Addressed issue with Cryptomatte invalidating caches on project load.
  • Addressed issue with 3D dome lights in stereoscopic 3D.
  • Addressed issue with incorrect upgrade dialog in some scenarios.
  • Addressed issue with playback performance with data burn in.
  • Addressed incorrect full screen behavior with single app window in ultrawide displays.
  • Addressed app window sometimes resizing when switching pages.
  • AI Voice Convert now requires graphics cards with 8 GB VRAM or more.
  • General performance and stability improvements.
